Overview Features Reviews
NEW
ELEMNT MINI Bike Computer
Reg: $99.99
SALE: $79.99
More Views
NEW
Simple cycling essentials to stay connected on your ride.
SKU# WFCC2
Reg: $99.99
SALE: $79.99
  • 30 Day, No Hassle Returns
  • 1 Year Limited Warranty
Reviews
Product Overview
Wahoo ELEMNT MINI is the bike computer for those that want max data in a mini package! ELEMNT MINI comes with two connection options: phone free mode and phone mode. In both modes, the ELMENT MINI pairs seamlessly with the Wahoo RPM Speed Sensor included in the box, as well as other Wahoo heart rate monitors and cadence sensors. It works with our free ELEMNT Companion App that allows you to set up your data fields, customize profiles, track performance, and share ride data effortlessly - no more confusing menus! When in phone mode, the ELEMNT MINI gives you ride tracking, full ride data analysis, and call & text pop-up notifications. MINI is designed to work only with Wahoo dual-band sensors to ensure the connectivity – and in turn your ride experience – is absolutely flawless.
BOTH PHONE FREE AND PHONE MODE
Works with Wahoo dual-band sensors
The ELEMNT MINI is designed to work with the Wahoo TICKR heart rate monitors and Wahoo RPM speed & cadence sensors. It does not work with Wahoo sensors that are Bluetooth or ANT+ only.
Wireless Connection & Uploads
A truly wireless bike computer, meaning there's no need to tether up to your laptop to sync up ride data, download routes, or update the software. Everything can be uploaded via Bluetooth Smart to the ELEMNT Companion App.
Companion App Set Up
The free ELEMNT companion app allows you to set-up customized profiles, track performance, and share ride data effortlessly.
Fully Customizable Screen
There's a page for every element of your ride. Customize up to 5 pages of the workout data that matters most to you! No menus or reprogramming required.
Smart Buttons
Two tactile and easy to press buttons on the bottom of the ELEMNT MINI allow you to quickly navigate to what you want to see and toggle between screens.
Partner App Automatic Uploads
Once sync'd with your favorite workout or cycling account, you are able send your data from ELEMNT MINI to your account with just one click via the free Companion App.
Speed Sensor Included
Wahoo dual-band speed sensor included so you can ride phone free with accurate speed, distance and time metrics.
1.8" Diagonal Screen Size
1.8" (45.7mm) diagonal display size that is larger than the leading competitor, so all your data is easy to see.
PHONE MODE ONLY*
Ride Tracking
When paired with your smartphone, record your ride via the smartphone's GPS so you have a full ride history of your route and ride statistics.
Live Track Portal
With Live Track, you can share a custom link with anyone via the ELEMNT Companion App so they are able to follow your ride in real-time on the Live Track web portal. Perfect for keeping you safely located by loved ones, tracked by a coach, or even meeting fellow riders in-route.
Text & Phone Alerts
Provides on-screen pop-up alerts to notify you when important contacts are trying to reach you. Available when you are riding with your smartphone.
*In Phone Mode, your smartphone must be with you on the ride and your ELEMNT MINI must be paired to the Companion App.
Click here for ELEMNT MINI instructions
Specs
Part Number: WFCC2
Physical Dimensions: 41x58.4x17mm OR 1.6x2.3x.67"
Display Size: 1.8" (45.7mm)
Weight: 1.1 oz or 31 grams
Battery: Coin Cell
Battery Life: ~1 Year
Waterproof Rating: IPX7 (waterproof up to 5 ft)
Shock Proof: Yes
Wahoo RPM Speed sensor included
ELEMNT MINI Bike Computer is rated 3.1 out of 5 by 60.
Rated 3 out of 5 by from Element Mini - Undecided So i bought this computer and honestly its great, BUT... there is always a But. I thought it would work with speed, cadence and HR but for some reason it didnt connect all three together. I couldn't find online anywhere that it didn't connect the 3. Other than that i loved the product but instead i upgraded to the Element.
Date published: 2018-12-11
Rated 1 out of 5 by from Hopelessly unreliable - avoid!! The features and design of this little bike computer are impressive and yet the whole system is flawed. Let's start with the sensors (you have to use the Wahoo ones): my speed, cadence, and heart sensors will randomly turn themselves on/off, connect/disconnect, and drain their batteries as they see fit. The app might record GPS routes on my phone, but probably not. The whole system is totally unreliable and pretty much unfit for purpose. I had more success with a standalone phone app which worked every time I needed it. Now I spend most of my rides checking that the stupid Wahoo is still recording. Utterly hopeless. I've never felt so strongly against a product and will happily throw it all away and buy something that will actually work.
Date published: 2018-11-10
Rated 4 out of 5 by from Great Product, some thoughts for improovement The mini wirks fine. But if the tour is started in the garage where no gps is available the tour will not be tracked at all - but the gps would be available just seconds later...elemnt could track after gps is available - but thats not the case. Transfering the routes to strava is not very relaible, would be nice if this works better (but i could not find a reproduceable issue for not uploading to strava...)
Date published: 2018-09-24
Rated 2 out of 5 by from More disadvantages than advantages As others have pointed out, there’s too many bugs to be considered useful. Apart from not recording in the middle of a ride, it has also decided to stop displaying the distance. Connection to cadence and speed sensors can also drop out without notification.
Date published: 2018-09-09
Rated 5 out of 5 by from Excellent product that works well I needed a simple cycle computer that would provide me with real-time heart-rate and speed information. The Element Mini does this very effectively and I am pleased with its performance. It is well-engineered, easy to use and connects automatically to the Wahoo Tickr and Speed sensors. I run it stand-alone as to reduce the load on my phone. The Mini comes with a secure mounting and I have it sitting on the top of the stem, immediately behind the bars. This makes it easy to see and it is mainly out of the wind. So, an excellent product if a little expensive.
Date published: 2018-08-31
Rated 1 out of 5 by from Bugs out halfway through every ride Very disappointed with this product. Was looking forward to being able to track just THREE things MPH, Ride time, and miles logged. Unfortunately this ELEMNT Mini keeps bugging out around 20 miles and simply stops tracking the miles. So disappointing. At least it tells time. Would not recommend.
Date published: 2018-08-23
Rated 3 out of 5 by from When it works, it’s great! This is the third Element mini I have purchased. i bought it primarily for the heart rate monitor function and because i wanted an idea of what i need to do to burn 1k to 1.5k calories. The hrm wirks just fine, but the calirie counter is intermittent on all three machines. Sometimes it works, other times it just sits on zero for the entire 2 hour ride. Not impressed with the product.
Date published: 2018-08-19
Rated 4 out of 5 by from Works as advertised I have been using it for about 2 weeks and despite some initial issues with the app and my unfamiliarity with how to have it connect to the Mini, it has been working well, measuring time, distance, heart rate, cadence, speed, calories. Just wish there was a K-Edge out front mount that it could fit on. Apparently only Bolt does.
Date published: 2018-08-04
  • y_2019, m_1, d_16, h_16
  • bvseo_bulk, prod_bvrr, vn_bulk_2.0.9
  • cp_1, bvpage1
  • co_hasreviews, tv_2, tr_58
  • loc_en_US, sid_WFCC2, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 21.38ms
Product Overview
Smart Buttons
PHONE MODE ONLY*
Ride Tracking
Live Track Portal
Text & Phone Alerts
Specs
Part Number: WFCC2
Battery: Coin Cell
Shock Proof: Yes
Reviews
