Overview Features Reviews
Wahoo RPM Speed Sensor
$39.99
More Views
Wireless Bluetooth and ANT+ Cycling Speed Sensor
SKU# WFRPMSPD
$39.99
  • 30 Day, No Hassle Returns
  • 1 Year Limited Warranty
Reviews
Product Overview
The Wahoo RPM speed sensor is the sleek, magnet-less solution for capturing cycling speed data. It easily mounts to your bike's front wheel hub, and the Bluetooth Smart and ANT+ dual band technology allows you to connect to and display data on both smartphones and bike computers. Tracking speed data has never been this easy.
Dual Band Technology
Wireless Connection
Magnetless
The RPM speed installs easily with no magnets required
Sleek, Lightweight Design
It only weighs 16.5 grams with the mount included
Speed Measurement
Provides accurate speed data during your ride
Hub Mount
Mount on any front wheel hub with a secure silicon casing
Visible Connection
Two LED lights show the sensor's device connection (blue) and speed detection (red)
Replaceable Battery
No charging required! Operates on a coin cell battery for up to 1 years.
Universal Fit
RPM Speed will fit with most bikes and frame sizes
Click here for RPM Speed instructions
Specs
Part Number: WFRPMSPD
Physical Dimensions (LxWxH): 1.25" x.75" x 1"
Weight: 7 grams (without mount)
Battery: CR2032
Battery Life: Up to 12 months
Water Rating: IPX7 (waterproof up to 5 ft)
Wireless Signal Strength Up to 10 feet
Wahoo RPM Speed Sensor is rated 3.8 out of 5 by 63.
Rated 5 out of 5 by from Simple as it Gets Purchased 2wks ago. Mounted, paired with apps and off I went.
Date published: 2018-10-31
Rated 5 out of 5 by from Better than the Garmin speed sensor I got tired of the Garmin speed sensor connection issues so I bought the Wahoo speed sensor.
Date published: 2018-10-02
Rated 5 out of 5 by from My Trainer Solution I was looking for a simple wireless speed sensor for use on a road bike set up on my trainer. The Wahoo speed sensor fit the bill with simple installation on the rear hub and instant pairing with the Wahoo Element. Zip ties and magnets attached to the spokes are no longer required.
Date published: 2018-09-30
Rated 1 out of 5 by from Many issues This seemed to work well at first but then I discovered that the speed sensor was not connecting to my phone and I was getting GPS data. The app needs a lot of work, it changes the wheel circumference on its own, I assume based off the GPS data which makes the sensor useless. The sensor no longer connects to the phone at all. Tried to email tech support and they were clueless. This is a great idea but it needs a LOT of work.
Date published: 2018-08-04
Rated 4 out of 5 by from Works perfectly. Wish it was a little smaller. Everything I have by Wahoo works perfectly. The Bolt computer and the speed and cadence sensors. This sensor paired instantly and the mount is pretty easy to use as long as you don't have wheels with too high of a spoke count. Maybe not easy enough to use to swap it back and forth between bikes every time I go riding, so I might buy some more of the speed sensors for other bikes. I just wish it was a little a less obvious, because it really kills the beautiful lines of my nice carbon wheels on my road bike. But nobody looks down on that because everyone knows what it is, so I guess it's okay.
Date published: 2018-06-25
Rated 4 out of 5 by from Great speed sensor I have been using the speed sensor and Wahoo app for a few weeks now for mountain biking. I love the speed sensor. I broke two computers before purchasing this and it is much better. Gives accurate data that I can share with other apps (Strava). The only thing I can see that needs improvement is the app. It is not very intuitive, there is no way to save wheel circumference for different bikes (should be a basic feature).
Date published: 2018-06-18
Rated 4 out of 5 by from Works fine, but mountadapter only fits with RB The mount adapter is only suitable for my racebike. My mountainbike's hub is to big for the rubber adapter. As workaround I use an additional rubber to prolong the rubber adapter
Date published: 2018-05-28
Rated 5 out of 5 by from just works. I like this sensor and it improves my data compared to GPS speed
Date published: 2018-05-16
  • y_2019, m_1, d_16, h_16
  • bvseo_bulk, prod_bvrr, vn_bulk_2.0.9
  • cp_1, bvpage1
  • co_hasreviews, tv_4, tr_59
  • loc_en_US, sid_WFRPMSPD, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 25.64ms
Product Overview
Wireless Connection
Magnetless
Speed Measurement
Hub Mount
Visible Connection
Replaceable Battery
Universal Fit
Specs
Battery: CR2032
Reviews
