Overview Features Reviews
$59.99
More Views
Bluetooth and ANT+ Cycling Speed and Cadence Sensor
SKU# WFBTSC02
$59.99
  • 30 Day, No Hassle Returns
  • 1 Year Limited Warranty
Reviews
Product Overview
The Wahoo BlueSC speed and cadence sensor transforms your phone into a powerful cycling computer. Using Bluetooth Smart and ANT+ technology, it tracks cycling speed, cadence, and distance which can be paired with your favorite cycling app including Strava and Zwift, or paired to your bike computer. It's weatherproof, small with a low drag profile, and comes with a rubber band and zip tie mounts.
Dual Band Technology
Both ANT+ and Bluetooth Smart capabilities allow for a wireless connection to both smartphones and GPS devices.
Wireless Connection
Speed Measurement
Provides accurate speed data during your ride
Cadence Measurement
Provides accurate cadence data during your ride
Bike Mount Option
BlueSC comes with a rubber band mount and zip tie mount.
Universal Fit
The Blue SC sensor will fit with most bikes and frame sizes
Click here for BlueSC instructions
Specs
Part Number: WFBTSC02
Dimensions (LxWxH): 3.5" x 1" x 3"
Weight: 36 grams
Battery: CR2032
Battery Life: Up to 12 Months
Water Rating: IPX7 (waterproof up to 5 ft)
Wireless Signal Strength: Up to 10 feet
Blue SC Speed and Cadence Sensor is rated 4.2 out of 5 by 202.
Rated 5 out of 5 by from So easy to use !! It connects with my Strava if I just want to use the app on my phone. Connects to the Element with no problem! It connects with my laptop if I am on the trainer and that is Ant+ to Zwift and Sufferfest !!
Date published: 2019-01-06
Rated 4 out of 5 by from Still a work in progress The cadence does not pick up on the Wahoo app? but it does on Zwift.
Date published: 2018-12-03
Rated 1 out of 5 by from It will not mount on my chainstay The design of the Speed sensor will not allow it to physically mount in the correct position on the chainstay. The wand for the wheel magnet it too thick and there isnt sufficient clearance from the spokes. It is impossible to position the wheel magnet such that is passes over the wand and not collide with it. To position the sensor so that the cadence magnet will pass in the correct location will prevent the removal of the back wheel. The rubber band securing piece is too short to wrap around the chainstay. Altogether this is a very poorly designed component. I will be returning it for a refund
Date published: 2018-12-01
Rated 5 out of 5 by from So simple Bought this to run with an Elment Bolt, really easy to fit on the bike, set up was so simple, just put the Bolt into pairing mode "find sensor" and spin the pedals/back wheel and it's done. Indoors I use a Tacx Neo Smart trainer, it pairs with the Neo on Bluetooth without issue and comparing the numbers on the Neo and the Bolt there is not really a significant difference in Cadence measurement, obviously it can't measure distance/speed as the rear wheel is removed on the bike.
Date published: 2018-10-31
Rated 4 out of 5 by from Not adjustable to fit all bike frames Upon getting the Blue SC, I was a bit upset that the speed monitor bar is only made to really work with smaller bike frames. I have it set up on my Felt tri-bike, and the speed sensor is so close to the magnet on the spoke that it will hit it each revolution if it gets even slightly moved. I have speed from the GPS on the ELEMNT bolt, but I wanted this for speed measurement while on my kickr. I will keep it, but I hope with next generations they consider bikes that have larger frame bars.
Date published: 2018-10-26
Rated 5 out of 5 by from Perfect to work with my polar V650 Easy to mount. You have to remove the left pedal, but the cadence magnet has a strong and secure fixing. It goes perfectly well with my polar V650.
Date published: 2018-10-03
Rated 3 out of 5 by from Ok when working, but didn't really fit my frame Bought this, but it never really sat flush on my frame geometry and frequently caused knocking against the spokes/magnet. In the end, I taped the speed sensor arm flush against the carbon tube and that stopped it knocking. On a recent ride however, during a sprint no less, the sensor hit the magnet on the spokes, ripped the tape off the arm, and the whole unit got spectacularly ripped in half by the rear wheel. Won't be buying a replacement.
Date published: 2018-09-25
Rated 4 out of 5 by from Works perfect Works perfect with Element Bolt. I had a little problem though attaching the speed magnet to the spokes of my Mavic Ksyrium wheel. Had to use a side cutter to make it fit (with the fear to make it useless)
Date published: 2018-08-23
  • y_2019, m_1, d_16, h_16
  • bvseo_bulk, prod_bvrr, vn_bulk_2.0.9
  • cp_1, bvpage1
  • co_hasreviews, tv_13, tr_189
  • loc_en_US, sid_WFBTSC02, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 21.11ms
Product Overview
Wireless Connection
Speed Measurement
Cadence Measurement
Bike Mount Option
Universal Fit
Specs
Weight: 36 grams
Battery: CR2032
Reviews
