Overview Features Reviews
Wahoo RPM Cadence Sensor
$39.99
Wireless Bluetooth and ANT+ Cycling Cadence Sensor
SKU# WFPODCAD2
$39.99
  • 30 Day, No Hassle Returns
  • 1 Year Limited Warranty
Reviews
Product Overview
The Wahoo RPM cadence sensor is your sleek little solution for measuring cycling cadence data. It's wireless, magnet-less, lightweight, and easily mounts to your bike's crank arm or to your shoe. Bluetooth Smart and ANT+ dual band technology allows you to connect to and display data on both smartphones and GPS bike computers. Collecting cadence data has never been this easy.
Dual Band Technology
Wireless Connection
Sleek, Lightweight Design
It only weighs 7 grams!
Cadence Measurement
Provides accurate cadence data during your ride
Two Bike Mount Options
(1) mount with double sided 3M tape, or (2) use the silicone sleeve and mount with zip ties.
Shoe Mount Option
The RPM can be worn on your shoe for spin classes or use with multiple bikes
Visible Connection
Two LED lights show the sensor's device connection (blue) and cadence detection (red)
Replaceable Battery
No charging required! Operates on a coin cell battery for up to 1 years.
Universal Fit
RPM cadence sensor will fit with most bikes and frame sizes
Click here for RPM instructions
Specs
Part Number: WFPODCAD2
Physical Dimensions (LxWxH): 1.25" x.75" x 1"
Weight: 7 grams
Battery: CR2032
Battery Life: Up to 12 months
Water Rating: IPX7 (waterproof up to 5 ft)
Wireless Signal Strength Up to 10 feet
Wahoo RPM Cadence Sensor is rated 3.8 out of 5 by 152.
Rated 4 out of 5 by from Now working well... I bought a Wahoo Elemnt Bolt bundle in early 2017. Really impressed by ease of set up and pairing of devices. All good except my cadence sensor ate batteries to the point where I stopped using it. However, I like to train with cadence so I fed it another battery and it died almost immediately. Contacted Wahoo Support who could not have been more helpful. Within 10 days I had a new sensor which works perfectly. (Only giving four stars as my original unit didn't work properly).
Date published: 2018-11-03
Rated 5 out of 5 by from Neat product I had problems to start with the sensor kept loosing contact with the Wahoo fitness app. I was using the device on my left shoe. After transferring it to the inside of my left pedal it worked perfectly.
Date published: 2018-09-25
Rated 1 out of 5 by from Awful I've owned this for approximately 1 year and I don't think its ever worked properly. I've put about 5 batteries in it, I've called Wahoo support, and reloaded the sensor several times without success. Do not buy....Completely frustrating!
Date published: 2018-07-19
Rated 1 out of 5 by from It sucks I can't get it connected with the strava app on my samsung S8?? On the box it says that it supports strava!!?? So help me out here, how can i connect the device with strava?
Date published: 2018-07-02
Rated 5 out of 5 by from It works 3 months riding every other day, I rely on cadence to stay in 90 range to minimize muscle fatigue over 3-5 hour rides and find Wahoo reliable.
Date published: 2018-06-05
Rated 3 out of 5 by from Adequate but some issues with reliability. I got this to replace a Blue SC that went kaput, figured it would be simpler and easier to move from bike to bike. I have been wearing it on my shoe and it seems pretty accurate and reliable at higher cadences but struggles with lower cadences. Anything below 65-70 rpm the readings start to jump around or cut out altogether. I also find it goes to sleep too quickly if you stop moving; then I have to unclip and shake my foot around together it going again.
Date published: 2018-06-01
Rated 4 out of 5 by from The mounting doesn't make sense I purchased the bundle and used the speed attachment for my cadence sensor. Easy on and off. The zip tie set up is a hassle when changing batteries. I don't trust the stick on tape. Quick on setup seems to work so far but just got the unit.
Date published: 2018-05-03
Rated 5 out of 5 by from Simple and works every time First and foremost I have two bikes so I use it on my cycling shoes and it connects and works every time. Just keep in mind with any of Wahoo’s sensors that you must make sure they are connected and working when on the bike. Then, start recoding/tracking your ride. I’ve not done that and the Wahoo Elmnt Mini I use will track every sensor feeding the unit data and not include those not registering data on the unit at the time start is pressed.
Date published: 2018-04-24
  • y_2019, m_1, d_16, h_16
  • bvseo_bulk, prod_bvrr, vn_bulk_2.0.9
  • cp_1, bvpage1
  • co_hasreviews, tv_10, tr_142
  • loc_en_US, sid_WFPODCAD2, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 14.86ms
Product Overview
Wireless Connection
Cadence Measurement
Shoe Mount Option
Visible Connection
Replaceable Battery
Universal Fit
Specs
Weight: 7 grams
Battery: CR2032
Reviews
